KuR » Вт апр 19, 2016 1:51 am
Вин не полный, объем двигателя не верный. Про какую базу речь? Каталогов з/ч полно везде, документацию или на сервисах проси или на сайте fca можно купить.
Я сомневаюсь, что DST - отдельный модуль. Это блок ESP (у Альфы VDC (Vehicle Dynamic Control)) дает команду рулевому на вмешательство в управление авто.
DST (Dynamic Steering Torque)
The VDC on the Alfa Romeo Giulietta intervenes in a discreet manner owing to its combination with the DST (Dynamic Steering Torque), the 'active electronic steering' that automatically carries out corrections and also controls oversteer over surfaces with low grip. The DST improves both driving safety and handling performance. In fact, in all driving conditions, the electronic steering suggests the correct manoeuvres for the driver to perform, allowing excellent grip performance and providing a great sense of safety. This is thanks to the continual interaction between the electric power steering (which generates the torque at the steering wheel) and the electronic dynamic driving control (VDC). In detail, the DST automatically carries out corrections, helps maintain vehicle control and makes the intervention of the VDC more discreet.
The DST system is especially useful in the event of oversteer, aiding the most appropriate manoeuvre to maintain vehicle control in all conditions. Moreover, the MCF (Mu-Split control function) intervenes when driving on surfaces with different grip (for instance, it is often the case in winter when two wheels are on ice while the other two are on the tarmac). In this case in particular, the DST system makes automatic counter-steering possible, permitting vehicle control (and avoiding the car spinning around) while at the same time minimising the stopping distance (which is reduced by 10%). Lastly, in sporty driving conditions, if the system detects greater lateral acceleration (from 0.6 g) it intervenes, by providing increased resistance torque to the steering wheel. This way, it considerably improves the driver's sense of mastering the car on bends, especially at high speed.
