глюк с альфа-кодом на 146
Сообщение Дима » Пн мар 13, 2006 1:48 pm
146-ая мотор 33501 1.4 .После попытки пуска двигателя на севшем аккумуляторе загорелся код и форсунка, машина отказывается заводиться.сброс клемм и разъема с мозгов не помогло.
есть карта с механическим и электрическим кодом .
Как его ввести?
Дима
Сообщение Racoon » Пн мар 13, 2006 2:02 pm
Emergency starting procedure (using the accelerator pedal): NOT foreseen for the TD version
This procedure should be carried out using the accelerator pedal and carefully watching the indications of the injection control unit warning light.
-Turn the key to MARCIA
-Press the accelerator pedal and keep it pressed until the warning light goes out.
-When the warning light goes out release the accelerator pedal.
-At this point the warning light begins to flash; after the number of flashes corresponding to the first number of the code on the Code Card (ELECTRONIC CODE) depress the accelerator pedal completely.
-The warning light turns on and stays on for 4 seconds then it goes out.
-When the warning light goes out, release the accelerator pedal.
-The warning light starts to flash again; after the number of flashes corresponding to the second number of the ELECTRONIC CODE, press the accelerator fully home again.
-Proceed in the same way for the other numbers of the ELECTRONIC CODE.
-Also after the last number, keep the accelerator pressed until the warning light goes out (appr. 4 seconds)
-Release the accelerator pedal.
If the warning light flashes quickly, it means that the operation has been carried out correctly, thus the car can be started: if the warning light stays on, the code has not been entered correctly, move the key to STOP and back to MARCIA again, and repeat the procedure.
NOTE: If this procedure is not activated correctly, check the throttle potentiometer and the corresponding wiring, and also the throttle itself (throttle stroke without obstacles or sticking); also check the supply to the C.C.M.
Racoon
Сообщение Дима » Пн мар 13, 2006 2:24 pm
пробовал ,после пятой цифры ,требует следующую,т е форсунка опять начинает моргать,после того как отпустишь педаль газа.
Машина 96 года боксер,может как по другому? И зачем мех код?
Дима
Сообщение Racoon » Пн мар 13, 2006 2:58 pm
И зачем мех код?
The Code Card, as well as the ELECTRONIC CODE ("E. CODE"), contains the mechanical code of the keys ("M. CODE"): through this code it is possible to request other keys suited to the ignition switch and to be memorised in the C.C.E.
А вводил две пятизначные группы?
Последний раз редактировалось Racoon Пн мар 13, 2006 3:02 pm, всего редактировалось 1 раз.
Racoon
Сообщение Дима » Пн мар 13, 2006 3:01 pm
sorry,после пятой цифры отпускаю педаль и форсунка начинает гореть постоянно
Дима
Сообщение Racoon » Пн мар 13, 2006 3:03 pm
Racoon
Сообщение Дима » Пн мар 13, 2006 3:04 pm
этот способ ввода единственный для boxer 1,4 или есть еще варианты?
Дима
Сообщение Дима » Пн мар 13, 2006 3:06 pm
try again не один раз,а в карте чипа нет,ее к замку не надо?
Дима
Сообщение Racoon » Пн мар 13, 2006 3:39 pm
В карте чипа нет. Это просто карта.
Могу выслать мануал. Там вроде бы нет отличий именно для боксера.
Racoon
Сообщение Дима » Пн мар 13, 2006 4:07 pm
да вышли если можно
Дима
Сообщение Дима » Пн мар 13, 2006 4:14 pm
и где чип?
Дима
Сообщение Дима » Пн мар 13, 2006 4:17 pm
иммо и ключ ковыряли осциллографом,обмен едет,антенна исправна,в чем еще может быть дело?
Или все-таки прдется менять мозги?
Дима
Сообщение Racoon » Пн мар 13, 2006 4:30 pm
Дай какой нибудь e-mail, а то с этого не уходит ничего.
Racoon
Сообщение Дима » Пн мар 13, 2006 4:49 pm
audioescort@mail.ru
nt_alf@hotbox.ru
отправлял сам себе на оба ,проходит.
Дима
Сообщение Racoon » Пн мар 13, 2006 4:57 pm
отправил на первый
Racoon
