Scorch Racing S15
Specs:
Max Power: 800 HP
Max Torque: 736NM (542 lb/ft)
Max Boost: 2.5 kg/cm2
Best time Tsukuba: 52”649 sec
Engine: Brian Crower 2.2L stroker kit, Nismo bearings all round, dry-sump lubrification, P12 Primera crank pulley, custom aluminium pulley for water pump, alternator & power steering pump, low-mount bracket for power steering pump, Denso lightweight alternator, SR20VE variable valve timing head, P12 Primera stock cams IN 228º~278º 12 mm lift, EX 244º~280º 11.15 mm lift, NAPRED high response head with: strengthened double valve springs, sodium filled EX valves, bronze valve guides, race cut valve seats, ported and polished head, Tomei t=1.8 mm metal head gasket ø 87 mm, Tomei head bolts, GCG Garret GTX3582R turbocharger, Turbosmart 40 mm comp gate external wastegate, custom ø 90 mm stainless steel front pipe, custom ø 90 mm exhaust system, custom intake pipe and Blitz mesh filter, custom intercooler piping, Blitz Type-J intercooler, Turbosmart Race Port BOV, Hypertune intake plenum & throttle body, Hypertune fuel delivery pipe, Blitz 1000 cc/min injectors x4, Blitz Type-D oil cooler, Tabata triple core racing radiator, Custom twin electrical fan set-up, NGK Racing Plugs #9, Odyssey 925 dry-cell battery, HKS F Con V-Pro ECU
Transmission: ORC triple plate clutch, ORC lightweight flywheel, Hollinger H6S 6-speed sequential transmission, Nismo GT-Pro differential (4.08 final)
Suspension & Brakes: Ennepetal/Bilstein adjustable suspension, Hyperco springs 12 kg/mm front, 10 kg/mm rear, pillow ball arms, solid/welded members, Brembo Racing 4-pot front calipers, ø 340 mm 2-piece Garland slotted disc, 2-pot Brembo rear calipers & slotted discs, Endless Type-R brake pads
Wheels & Tyres: Rays Engineering Volk Racing RE30CS 10.5JJx18”, Yokohama Advan A050 295/35/18 GS compound
Exterior: custom carbon bumper, custom carbon canards, custom headlight dummies, custom carbon vented hood, custom carbon fenders, custom carbon doors, custom carbon rear overfenders, T&E Vertex dry carbon roof, custom carbon side & rear glass covers, custom carbon trunk, Craft Square carbon mirrors, custom designed adjustable rear wing
Interior & Chassis: 14-point ø 40 mm cromoly racing roll cage, spot welded chassis, Recaro SP-G bucket seat, Nardi racing steering wheel, Racepak IQ3 data logger dash unit, Blitz boost controller, Lap-Shot LP-03 lap timer, oil reservoir catch tank
