MB C63 AMG
Re: MB C63 AMG
Сообщение Kemal » Чт июн 10, 2010 12:43 pm
Typhoon писал(а):
Kemal писал(а):а вот даже CTS Coupe, о котором я всерьез думаю, будет поставляться с МКПП!
На седан -V РКПП ставят с самого начала производства, как опцию. Соответственно, на купе тоже самое. Понятие рулежки у американцев, к тому же у Кадди своеобразное. Но на серии V устанавливают перестроенные аммо магнетик райд, по идее не должно быть валким и размазанным поведение тачки. Жаль, не будет оф. поставок...
ну про V понятно, но я так понял, что РКПП и на обычные ставится как опция
The coupe also largely carries over the sedan’s mechanicals, although there are a few key tuning changes. “The coupe turns it up one notch from where we are with the sedan,” said vehicle performance manager Richard Kewley. The coupe’s body is two inches wider in the back, which allowed engineers to go with wider rear tires. They offset that change with a thicker rear anti-roll bar to provide more overall grip without hurting the car’s balance. The direct-injected 3.6-liter V-6 is unchanged from the sedan but is paired with a numerically higher, 3.73:1 final-drive ratio (the base 3.0-liter engine will not be offered) and a standard limited-slip differential. According to Kewley, when the CTS coupe is equipped with a manual transmission, it should be able to accomplish the 0-to-60-mph sprint in about six seconds....
Most important, the coupe is every bit as sporty as the fighter-jet looks promise when it hits some curves. The FE3 suspension on our tester manages the car’s considerable weight with supreme competence, keeping body motions in check through quick switchbacks. The extra time spent on tuning pays off with exceptional balance, as the rear end slides around hairpins smartly and predictably despite its staggered tires. This, just in case you were wondering, is where the CTS coupe would leave a V-6 Camaro choking in its dust, despite the fact that it uses an identical powertrain and weighs about the same. The ZF steering rack, unchanged from the sedan, is extremely precise and is as communicative as that in any German car, though there’s still a bit too much power assist for our taste.
Re: MB C63 AMG
Сообщение Эка » Чт июн 10, 2010 2:12 pm
Typhoon писал(а): Машина очень живая, она разговаривает, причем делает это коротким рявкающим металлическим лаем бойцового питбуля, выходя на апокалиптические ноты на высших оборотах. Звук 5 из 5!
Эко завернул!!! 8)
Typhoon писал(а):Главное-это совершенно особый и красивый цвет сандолин, оттенка кофе, в котором очень много молока и с добавлением металлического оттенка с титаном.
вчера ехала по яузе :-D и встретился мне старый Скласс купе
вот такой
только цвета как Мурзила! ну может быть чуть меньше молока...
за рулем сидел поджарый дедуля, интеллиентный и не слишком старый :D
и подумала я, что время быстро бежит, и с каждым годом смена моделей все чаще, и если Саша будет вовремя менять резину ...
:-D :-D :-D
ideato, progettato, costruito in Italia
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Эка » Чт июн 10, 2010 2:16 pm
Typhoon писал(а):Есть еще одна интересная фича-это функция шифтлайта у главного прибора-спидометра. Я сначала жалел, что тахометр на панели достаточно мелок для того, чтобы уверенно считывать показания при спортивной езде. Но неожиданно выяснилось, что в ручном режиме спидометр работает как шифтлайт. При достижении критичных оборотов дисплей спидометра (ободок) загорается красным светом и появляется жирная надпись SHIFT UP, тоже красная. Так что момент переключения не пропустить, все предельно правильно сделано.
ухты! какая штучка! вот бы мне такую в Спайдер :lol:
Typhoon писал(а):Впечатления и заметки о C63AMG
Хорошо написал! :D
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Typhoon » Чт июн 10, 2010 2:57 pm
Эка писал(а):ухты! какая штучка! вот бы мне такую в Спайдер :lol:
В спайдере такая штука совсем лишняя, спайдер-это пусимагнет и лейзи лайф, неторопясь фланировать в очках-консервах от Диор (классик колекшн), лениво перекладывая взгляд глаз с правого тротуара на левый в поисках восторженных подростков и налитых тостестероном дядек с 90% оволосением поверхности тела, демонстрируя всем заинтересованным свой ровный загар с южного берега Франциисолярия на павелецкой и новый шарфик от Шанель :-D Шифтлайт-это удел высокодинамичных дрюч, в которых надо валить на пределе производительности своих потовых желёз, потея ладошками и другими частями тела, простреливая пространство и время, сжимая расстояния и истекая адреналином, наслаждаясь контролем над адским механизмом, который при малейшей возможности рад обернуть тебя вокруг столба или прислонить о разделительный рельс. :-) Один прострел на такой дрюче равен двум сезонам вялого копчения на кабрике и заменяет сразу пару ночей с женщиной из десятки лучших порнозвезд знакомых :-D
Эка писал(а):Хорошо написал! :D
Благодарю на добром слове! Всегда приятно, когда ожидания от тачки оправдываются и хватает задора написать о ней текст на пару А4 )
Re: MB C63 AMG
Сообщение Эка » Чт июн 10, 2010 4:27 pm
Typhoon писал(а):спайдер-это пусимагнет и лейзи лайф, неторопясь фланировать в очках-консервах от Диор (классик колекшн), лениво перекладывая взгляд глаз с правого тротуара на левый в поисках восторженных подростков и налитых тостестероном дядек с 90% оволосением поверхности тела, демонстрируя всем заинтересованным свой ровный загар с южного берега Франциисолярия на павелецкой и новый шарфик от Шанель :-D
Кемаль??? :-D :-D :-D :-D
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Kemal » Чт июн 10, 2010 4:28 pm
Новый шарфик от Кемаль :-D :-D :-D
Re: MB C63 AMG
Сообщение Эка » Чт июн 10, 2010 4:36 pm
нет-нет, совсем не помешает, при перекладывании взгляда краем глаза улавливать красную надпись, напоминающую о том, что ты все ж в авто в очках-консервах, а не на теплом песке в мини-бикини 8)
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Эка » Чт июн 10, 2010 4:37 pm
хм, я бы не отказалась :-D
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Defined » Чт июн 10, 2010 6:14 pm
Эка писал(а):
Typhoon писал(а):
Defined
Оби-Ван Кеноби
Авто: Blu Monica ™ 3.0
Re: MB C63 AMG
Сообщение Эка » Пт июн 11, 2010 12:16 am
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Defined » Пт июн 11, 2010 12:53 am
Defined
Оби-Ван Кеноби
Re: MB C63 AMG
Сообщение Эка » Пт июн 11, 2010 12:58 am
Эка
блондинго асоциале
блондинго асоциале
Re: MB C63 AMG
Сообщение Mur » Пт июн 11, 2010 1:36 am
Эка писал(а):
Mur
Альфапонты "!"
Re: MB C63 AMG
Сообщение sap » Пт июн 11, 2010 3:20 pm
sap
Авто: alfa-romeo 166
Re: MB C63 AMG
Сообщение mc240 » Пт июн 11, 2010 10:45 pm
сцуко,600 момента.увижу такой,задираться не стану.а я то привык,понимаешь,в диапазоне 60-120 на моменте понтобензины объезжать.
пойду рыдать.
mc240
Авто: e61,c4
Вернуться в Народ свободы
