YuriV6 писал(а):Почистить контакты разъема, сбросить ошибки экзаминером, прозвонить контакты от педали до мозга. Как-то так.
rahmanoff писал(а):Сброс делали?
ME2.1 injection/ignition control unit
The control unit is mounted in the interior compartment on the passenger side panel.
The control unit's memory is "flash EPROM", i.e. reprogrammable from the outside without intervening on the hardware.
The replacement of the injection control unit or throttle body actuator means that the self-learning procedure has to be carried out:
ignition turned on for 30 seconds
remove key for 5 seconds
Start the engine.
