ESP/VDC Problem
ESP/VDC Problem
Сообщение Kamen666 » Сб сен 06, 2008 5:09 pm
Hi to everybody,this is my first post here,and i'm beging for help
Before one year i bought a Alfa Romeo 156 12.2002 1.9 JTD
I love this car !
But from one month i have a serious problem
The ecu give me a constant mistake in VDC in my car
I go about 5-6 six service,they put my car on tester and nothing....
The mistake is:
C 1520 - Can terminal -> bad connection
C 1521 - Can Terminal -> bad connection
and nobody can delete this mistake from ECU,and nobody can help me here in Bulgaria...
Can you please tell me where i can find these terminals to clean them (whit a contact spray for example),or can somebody show me a grafic or something helpful.
this forum is my last hope.....
Sory for my bad english
Greetings from club alfa romeo bulgaria
Sincerely
K.Todorov
Kamen666
Re: ESP/VDC Problem
Сообщение andylook » Сб сен 06, 2008 8:08 pm
I didn't get... does the system work or not?
Or u wanna just delete the errors?
+7 929 677 22 99
andylook
Авто: AR 166 2.5
Re: ESP/VDC Problem
Сообщение Kamen666 » Сб сен 06, 2008 10:10 pm
The system doesnt work....
ASR is off at all the time
i want to clean this "can terminals" and everything will be fine,but i dont know where to find these terminal clam/axle
maybe they are somewhere under the dashboard...
Kamen666
Re: ESP/VDC Problem
Сообщение ghibli » Сб сен 06, 2008 11:22 pm
Does the ABS working on your car with this failure?
Try to check the ABS sensor elictrical line from wheel's hub to ECU... It's can damaged!!!
ghibli
Re: ESP/VDC Problem
Сообщение mxo » Сб сен 06, 2008 11:34 pm
I suspect this has something to do with the steering wheel angle control sensor ,
try to undo the top end of the steering wheel and check the wiring with it's terminals.
Anyway it would be better if you could find a service with an Examiner because in case of the sensor failure it has to be calibrated after it is refitted.
The wiring is a never ending story with alfas, there are always issues with them.
If it was the VDC with the ABS together then I would recommend to change the battery but this is not the case.
mxo
Авто: 156 2.0 TS
Re: ESP/VDC Problem
Сообщение Kamen666 » Вс сен 07, 2008 10:40 am
ghibli писал(а):Does the ABS working on your car with this failure?
The ABS is working at all the time,i allready check the sensors and wires,and everything is ok
Kamen666
Re: ESP/VDC Problem
Сообщение Kamen666 » Вс сен 07, 2008 10:44 am
mxo писал(а):I suspect this has something to do with the steering wheel angle control sensor ,
i'll check today the steering wheel,but i dont think that the problem is there
my car battery is brand new
Kamen666
Re: ESP/VDC Problem
Сообщение Kamen666 » Пн сен 08, 2008 10:14 pm
mxo
thank you very much
you are the man :)
I remove the top end of steering wheel and voala ,one jack was corrupted
Now everything is fine and i love my car more.... :)
Kamen666
Re: ESP/VDC Problem
Сообщение mxo » Ср сен 10, 2008 9:48 pm
Always welcome ! Enjoy :)
mxo
Авто: 156 2.0 TS
