Specifications
ENGINE:
Type V12, 60°, MPI
Displacement 6498 cc
Bore and stroke 95 mm x 76,4 mm
Valve gear Variable valve timing electronically controlled
Compression ratio 11.8 ± 0.2
Maximum power 700 HP (515 kW) at 8250 rpm
Maximum torque 690 Nm at 5500 rpm
Emission class EURO 5 - LEV 2
Emission control system Catalytic converters with lambda sensors
Cooling system Water and oil cooling system in the rear with variable air inlets
Engine management system Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
Lubrication system Dry sump
DRIVETRAIN:
Type of transmission 4WD with Haldex generation IV
Gearbox 7 speed ISR, shifting characteristic depending on drive select mode
Standard AMT 27
Clutch Dry double plate clutch, 235 mm
PERFORMANCE:
Top speed 350 km/h
Acceleration (0–100 km/h [0–62mph]) 2.9 sec.
DIMENSIONS:
Wheelbase 2700 mm
Overall length 4780 mm
Overall width (excluding mirrors) 2030 mm
Overall height 1136 mm
Track (front – rear) 1720 mm - 1700 mm
Dry weight 1575 Kg
Weight distribution (front – rear) 43% - 57%
PRICE:
UK GBP 201.900,00 (suggested retail price taxes excluded)
Europe € 255.000 (suggested retail price taxes excluded)
USA 379.700 USD (suggested retail price – GGT included)
China RMB 6.270.000,00 (suggested retail price taxes included)
Japan YEN 39.690.000,00 (suggested retail price taxes included)
